phantom II
Post a picture of the damage, let's see.
Well Bob since you asked . Look at the dimple in in that windscreen .
That's what happens when you are polishing a vac form transparency with a buffing wheel and it jams between it and the cowling.
Heat and pressure was not my friend . It is by no way burned up . Just deformed a bit.
I had no idea those cowls would interfere with the polishing :idonno
Definitely don't want to give it up but every time I look at it I get green around the gills
I need a definite plan before I try to fix it .
Thank Mike and Warren for the thoughts and encouragement.
Cheers, C. B)
