chrispisme
Inspired from the cover of "A Higher Call" Kicked around 5-6 years and finally pulled the trigger.This is in 1/32 scale.
The 109 element is nearly completed, decalling still needs to be finished but now I've started work destroying HK models B-17 E/F for the Charlie Brown component.
The pilot is from Master Details, the kit is Revell's G-6 with a couple of resin bits added.
The B-17 is currently undergoing surgery to thin the plastic for the mass of damage done during flack bursts and fighter passes. I have, after a couple of weeks, think I've got enough panels ready to build and damage the nose. As well, I've cut up the control quadrant to show the non symmetrical throttle settings (#2 shut down #4 at reduced power)
The nose with panels being thinned between ribs/stringers;
throttle quadrant;
throttle quadrant;
